- Jan 4, 2012
Okay, so i'm pretty new with overclocking.. i recently overclocked my gpu and things have been going smooth since. I wanted to play Everquest 2.. and soon found out that its engine relies on the cpu rather than the gpu, so my card is worthless for this game. I experienced a lot of graphical lag, and after a while i decided i wanted to overclock my cpu.. but that could cause my mobo to fry if i do it wrong, so here i am looking for some guidance to possibly build and help me with overclocking my cpu. I'm also wondering if my mobo is good for overclocking this particular processor; my motherboard is a Gigabyte GA-880GA-UD3H.
I overclocked just a tad bit using the BIOS mostly and AMD Overdrive.. i got my cpu to go from 2.8ghz to 3.15ghz.. and performance significantly increased on my computer. I turned off Turbo Core technology, still have my cpu locked, and i disabled the Cool & Quiet technology as well. I'm stress testing as i type this, and i'm receiving temps of around 70°C using OCCT and Core Temp.. is that good? When my cpu is idle, i receive 48°C to 50°C. I'd like to add that it's pretty damn cold in my basement too lol, and that everything is stock fans for cooling.. i have a Cooler Master case (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227). Anything i might need for cooling, i'm willing to shell out some cash. If there's anything i need to put up for you guys to help me, i'll be more than glad to provide.
My specs are as follows..
Processor: AMD Phenom II x6 1055T Thuban 2.8ghz (3.15ghz now)
Motherboard: Gigabyte GA-880GA-UD3H
Video Card: ATI Radeon HD 5670 1GB x2 crossfired and overclocked
Power Supply: Raidmax Hybrid 2 RX-730SS 730w
RAM: 4gb x2 (8gb physical, 20gb virtual)
Hard Drive: 500gb WD Caviar Blue
Any help would definitely be appreciated. I'm also not exactly sure what to provide for you guys to help me.
