So when you see 533 in CPU-z, think 1066. When you see 666, think 1333. When you see 800, think 16000, etc.
The other thing I wanted to come back to is the effect of overclocking with the system bus (CPU frequency). It is the master bus of the computer and there are three subsystems that march in lockstep with it. Namely: the ram frequency, the HT Link frequency and the CPUNB frequency. When you raise the system bus these other three things get faster along with it. If any one of them exceeds what it can handle the system will become unstable. That's why you have to back in bios and lower those multipliers. The HT Link is very sensitive that way and doesn't like to exceed the stock 2000 mhz by much at all and there is no real performance advantage in trying to do so anyway. The CPUNB can handle a larger amount of overclocking than the HT Link and will often be stable at 2600-2800 with a little bit of extra CPUNB voltage. Overclocking the CPUNB has some definite positive effect on memory performance since its part of the integrated memory controller. The ram can usually be overclocked to some extent but since the AMD integrated memory controller is rated at 1333 mhz the ram can often not be overclocked to the full extent of its limits.
Overclocking with a "black edition" CPU is simpler because you don't have to increase the system bus; you just raise the multiplier. Next time, consider getting a black edition CPU.
