I saw the graphs at the end which is all I need to see.
The FX 8300 is not at all bad nor is the Ryzen and as I said before AMD can and does game just as good as Intel.
There are tons more that show this same thing. you may say oh you are wrong but from what I see a 6 year old system holding up well. Given the fact that the FX 8300 is DDR3 and not DDR4 it is IMPRESSIVE to me. Must be a nut punch for you Intel boys though.
Trickson, you are spot on that the results are much closer/different there. They are closer because of a reason I already mentioned (post #37), because its tested at a GPU bound resolution of 1440p (so much for that nut punch...). My points are with a 1080p resolution (72% of people on steam use one... 3% for 1440p), where the CPU matters more. It is funny though you post that link for support and in the same post, talk about how jacked up the clocks and such are. For the record, the link wingman and I provided shows what I am saying at 1080p. Wingman's link shows them all at 4 Ghz 1080p res, and the link I showed is all at stock speeds 1080p.
Last, let me say that nobody here is disaparging AMD. I simply disagreed with the blanket assertion AMD CPUs are "just as" good as Intel CPUs when it comes to gaming. They are, in many titles, not as good unless they are at a higher resolution. AMD does offer up great performance /$, especially if you can use the cores. This isn't a point anyone has disagreed with. Its valiant you are jumping in to defend them, but, the arguments just aren't there and they never needed it in the first place. We know the merits of the chip and are thankful for its existance if only for competition's sake.
EDIT:
In games what matters is graphics card.
Right. Of course...Buuuuuuut, I don't see your point here when all that was said is they can put a glass ceiling on processors...surely the GPU matters, even at 1080p... that doesn't mean a CPU can't hold it back, regardless of clocks. The people who run 1080's and 1080TI's at 1080p, the high refresh rate peeps) NEED every ounce of horsepower they can get out of a CPU. ANd in many titles, the AMD CPU caps performance... even with a 1080 at 1080p with Ultra settings. 60 hz too! Who wants to cap their performance in any situation? Yeah, sure strap a governer on my bike because I can't go past the speed limit anyway..........
Can we (all) please stop throwing logs on the fire about the Intel and AMD comparison? I figured my clean up post would stop it... but apparently it has to be repeated.
NO MAS, POR FAVOR!
