- Jan 23, 2001
Thoughts regarding benches from different sites:
At xbit, they compared the APU with DDR 1866 to a DDR5 6570 dGPU and only gained about 10% in games. The 6570 is a notch above the 6550 in a top end Llano (which uses ddr3 system ram).
At the same site, they showed incremental APU gains from ddr1600 to 2300 totalling around 10-15%.
At Anand, the A10 apu benched </=10% better than the A8. I'd expect a much bigger spread from a gain of 50% more radeon cores (and a nominal 5% clock speed increase).
The A10 is ~10-20% behind the i3 with a relatively old discrete HD5830 (@Anand). Most of the other dGPU comparison tests seem to be using top end cards.
It seems that the Trinity APU is about as good as any low/mid range DDR3 dGPU and the APU is significantly memory bottlenecked. Since the DDR5 cards start at around 70 bucks, it could be argued that Trinity doesn't make any sense once you've got a card that good, and a dGPU isn't really worthwhile at all below that point.
It's too bad ddr2400 is so pricey. What are the best overclocking 1866 sticks? Also, the A10 doesn't seem to be worth the extra money over the A8. Perhaps DDR3 system ram can't take advantage of the extra Radeon cores.
