- Mar 7, 2008
My take on that article is that the SLI/crossfire problems might only start if you go above two GPUs, which isn't exactly a big thing so I don't think is too critical.
The ram, it just sounds like they need a bit more time to refine it. In the early Skylake days, there were fast and frequent bios releases mostly saying "improve ram compatibility" for a long time. Zen's motherboards would likely go through a similar process for higher speed ram. I've tended to find once the speed goes to around 3000 or so, module and mobo compatibility is never as simple as it should be. The thought of having 8 fast overclocked cores and slow dual channel ram makes me sad.
Mobo pricing, while it is new I can understand mobo manufacturers trying to claw what they can. The cheaper than Intel talk was usually based on the assumption the Zen mobos were simpler than Intel counterparts, thus could be made cheaper.
CPU pricing wise, I'd hope for more of a spread than EarthDog's guess. I'm thinking the high end would be higher, and low end lower, with more models filling out the space. For overclockers, the lower in each configuration, the better...
