does anybody use this psu?
been looking but cant find a review for it
http://www.ebuyer.com/product/161664
For £89.99 from that site I don't see anything better in 750W range. TX750 is a CWT PSH and EA750 is a Delta. I dunno what to say, if he wants modular EA750 is perfect fine.Im sure it will be fine but there are better for the money.
thanks didnt see them not sure if i want modular but for the extra £s i might,
problem with my case its the antec 900 gaming so psu at bottom and 24 pin atx and 8 pin atx are at the top of mobo so thats why i looked at modular leave a few cables out,
are there any other benifits from modular psu's? (like more stable rails etc)
Geeman,
Since you're running SLI, there isn't much advantage to modular, you'll use most if not all of your cables anyhow. You should find out your cable lengths. It's not usually an issue but some may be too short. Your extra 12v cable can be tucked away in the back of your case. I know the Corsair TX750 cables are plenty long enough.
the True Power New are modular aren't they?...well they're half modular anyway.i would go with modular man that way you dont have to have a bunch of molex and sata power plugs all over the place...
ey man, why not get the Antec True Power New 750w?
it's newer and i'm assuming, better quality.
i've read good reviews of it
the new Corsair HX-750 is also top stuff
