The Nh-d14 was so close yet so far away....
I run prime 95 for 20 mins at a time to find semi-stable (what - ever that means. When I think I've found my final 24/7 clock I run it for 2 hours. If temps stay good and no errors...good enough for me. I know others that let it run for days before they call it STABLE. But that seems nuts to me...Just sayin. Lol
No had a bunch of ordering and price problems and when I finally did get it it didn't have the motherboard mounts. I was soo mad the whole time and just returned it f or a refund.What do you mean? Did it not clear the RAM?
ya lol. 20 minutes seem ok. Just wish there was a really fast way to test lol.
I am looking at guides and stuff but this is my first time so I really don't know what is normal or what to expect.
Right now I am running at 4.3 but I had to turn the voltage to 1.35. But in the prime 95 test it stays under 1.3 except for a quick second where it jumped to 1.344v. This type of thing normal? (It was running fine at 4.3 on stock voltage but after like a few minutes prime 95 would say worker failed so apparently that means I r needs higher voltage. I guess I'm confused because after raising the voltage it says under 1.3 v)
Also is there a max safe voltage or does it just depend on heat. A few places say 1.5v max but others have gone higher.
A little tedious but definitely fun!
I wish there was a faster way too, but such is life.
As far as max safe voltages...I believe AMD states 1.5v as their max, I personally like to keep it right around 1.45v. The very slight OC improvement I get isn't worth the extra heat produced. Plus I feel my CPU should last longer with the lower heat/voltage. Of course with that said it's pretty well excepted that OCing in general reduces the life of your CPU, but there's really no way to prove that as each chip is unique.
I am satisfied.
