- Oct 14, 2011
- Southern Indiana
Ok, then it's odd, becuase my new GPU also calls it HDMI, but perhaps it is a display port instead, I need to go check the specs. so DVI is still going to be a better connection right?
Something you all need to consider about this monitor is the way in which things plug in it, because of the bulkiness of it, getting things plugged into the bottom are a bit tricky, once in of course it's great, but for example two of the usb ports on the bottom and two are on the side, I suppose whatever you plug into the usb should be more permananet such as a mouse or keyboard or camera or cellular phone plugs, which is what I plan to do, the two on teh side are useful for usb pens and other stuff...
Got a question for you guys, why is it that the text only looks normal at the 1920x1200 resolution setting? When I try to adjust the resolution down, in order to make the text bigger the text looks fuzzy, especially in outlook mail and desktop icons. right now I am using my old computer with the monitor, the spcs in blue below, with only a DVI connection, could this be the problem?
In addition can someone here give me an idea of a good display test software to check for dead pixels and other perforamace issues? I want to make sure everything is working great within the 14 day exchange period.
Thanks
Some video cards have HDMI, but more of the newer ones are putting on either Displayports, Mini-display ports, or both displayports and HDMI. Your video card, for being as old as it is, doesnt look like it has either one of them. But that would depend on the adapter they gave you. (it would be the round port if any). You could also get a DVI to HDMI converter, if you were so inclined. But most only do that to plug into a 1080p TV instead of using the D-sub (Vga) port.
The text looks blurry because of how LCD displays work. Even LCD TV's do this. 1920x1200 is your monitors Native resolution, which means it looks its best at that resolution. Setting it lower, just degrades the image. (more on this here)
So if it bothers you that badly, your choices are to get a display with a lower resolution, or go back to a CRT.
