- Jan 29, 2007
I guess a whole lot has changed then, and maybe for the better. When I first bought my syncmaster from Samsung they told me to use both VGA and DVI together and even showed me the difference with just using VGA vs. using both, in order to get a better quality picture you had to use both.
So which one is going to be better DVI or HDMI? I suspect that DVI will begin to be phased out at one point or another just like VGA? I suspect VGA is on the way out also, no? The new standard may be HDMI? Perhaps I should just adapt to it now...
EDIT: and by the way, so far I love this monitor, the on panel controls for brightness and contrast are great! The only thing I don't really like so far is that the monitor does not go high enough and that the screen tilt doesn't automatically figure out which way is up, though perhaps this is good as for some reasons maybe you wouldn't want to monitor to flip by itself like a smartphone would. I am quite impressed so far, though I will say when windows loads it flickers at the beginning, and I am wondering if others are experiencing this, so far I have only used the VGA connections, and that could be what is causing it. When windows loads, right before it brings up the main screen inside with your background on it the screen goes nuts horizontal like it is scrambled or something, maybe someone else can shed some light on that.
