- Feb 14, 2008
- Chicago, IL
Hello everyone. I'm going to be putting some DD waterblocks on my QX6700 & 2 8800GTXs, and I'm curious how I should apply MX4 thermal paste to them.
From what I've read about the QX6700, the proper method is a roughly 1mm thin line across the cores in the middle (see attached image) & to let the waterblock spread it out. Is that a correct application method for MX4? (I'm asking because that attached illustration is from AS5's website & I'm thinking it's possible that MX4 is different.)
For the 8800GTXs I haven't been able to find solid information.
On the GPU, should I apply a grain-of-rice-sized amount or a pea-sized amount in the middle? Afterward, should I spread it out evenly or let the waterblock do that when I press it on there?
On the 12 memory spots around the GPU I have basically the same questions. Should I apply a small dot in the middle of each or a grain-of-rice-sized amount? Afterward, should I spread it out evenly or let the waterblock do that?
I have also attached an image of the 8800gtx. If anyone would like to take a couple seconds in paint to illustrate the size of the paste I should put on the GPU & 12 memory spots it would be appreciated.
