moonshake Member Joined Mar 6, 2007 Jul 24, 2009 #1 Hey there, Anyone using the Asrock DUAL SATA2 with SSD´s attached to the SATA or SATAII ports? Is worth it? Please comment! Thanks in advance
SeasonalEclipse Member Joined Feb 21, 2006 Jul 24, 2009 #2 Depending on the SSD it would be if your looking for a performance jump for load times. What are you planning to do with it? Use it as a OS drive?
OP moonshake Member Joined Mar 6, 2007 Jul 24, 2009 Thread Starter #3 A 60gb Vertex and/or 80gb X-25M for example... Do they work in the Dual SATA2? Yes, I´d be for OS and Apps.
