Did you mean to say "all the way to 1.5 and even 1.8?" Read your sentence.
One thing that is going on is that you are getting what they call "negative vdroop", where the motherboard is compensating for the normal drop in CPU voltage under load, called "vdroop". Mine applies negative vdroop like yours does. I have mine set to 1.4v in bios but under load it climbs to 1.51. It actually limits my overclock because I'm scared of having the vcore go higher than that. A lot of high end motherboards actually have a bios setting that allows you to program the amount of negative vdroop. I can't think of the name of the setting right now, though. It can be enabled or disabled. Unfortunately, my board does it automatically so I can't turn it off.
