Alaric
- Dec 4, 2011
- Satan's Colon, US
I have an old Asus mobo that worked just fine when I retired it. Last night I decided to see if I had enough old parts to slap together a functioning back up rig. When I tried this mobo everything seems to work, CPU fan spins up and cycles from high to a lower speed, light comes on, HDD sounds like it's doing something. I got no signal from the onboard graphics chip. I tried all three ports (VGA, DVI, HDMI) with different cables and three known working monitors. Next, figuring the old Radeon HD 4200 gave up, I tried two different graphics cards and got the same results. Bot cards work, all monitors I tried work, and all the cabling I tried works. I also tried two CPUs, a Phenom X4 9850 and a Phenom II 980 BE, with every iteration listed. Same results. I tested both CPUs in another mobo and both worked with no issues. Same with three different RAM sticks.
I cleared CMOS and found no problems with a couple hundred visual inspections. If there was a PCIe failure, would that affect the onboard graphics? I had OC'd the PCIe on the board previously, but never ran it over 110% and never touched the voltage. It was only for a few minutes (leading to the discovery that OCing your PCI will break your Windows faster than a myopic Berkeley with a box of rocks). It ran fine for over a year after that. About 5 years ago I had to RMA the original board and got a brand new one back from Asus, so its service life was only around 3 years. I'm all out of skills and experience on this one, so I'm open to suggestions.
