For 4.5 I would put vtt and as around 1.1. Pll around 1.8 (pull it down as much as possible once pc is stable). Dram at whatever your ram is rated for. Gfx doesn't matter, leave it at default unless you are ocing onboard.
Vcore probably between 1.2 and 1.3 for 4.5ghz.
Maybe someone else can help him with the other mvg for 4.5 settings. I haven't ran air.
Yep, normally from a person at Asus named Shamino (Shammy) or Raja.
He posts a decent amount here: KPC Shamino Section
and http://hwbot.org/forum/showthread.php?t=42040
Nicely done, I have to break out the BBSE and PSC and test it out!
woomack, looks like you are getting ready for some supi32 action. those timings and speed look delicious
yeah. Looking good. Top (only) pcm05 3770 too!
Interesting that no one has submitted for that before now.....
I am regretting canceling my newegg order and saving a few bucks at MC.
Thank you all
Spi 32m @2626 7-12-7-28 1T ( also posted in other thread )
No good access to cheap LN2 so I run on SS. Memory on air.
and max valid so far 3036.2 http://valid.canardpc.com/show_oc.php?id=2359009 ( memory also on air )
