Hello fellas,
Spec:
motherboard: ASus p5kc
DDR2: 4sticks kvr1066d2n7k2/2 (kit of 2 1.8v)
proc: q6600
GPU: 8600gt
PSU ANS 450w, (it was working for 5 y.)
Last 2 things I did with my PC is:
I upgraded bios to 1203 (was 0701), after upgrade had to pull out all memory stikcs and it worked, but then I wanted to clock it a bit to 3.0 proc, but it was unstable.
Last what I did is I tried to push DDR2 to 2.0V which is maybe a bit more than it can coop with.
From that point on my computer is making a constant loop, no POST, no BIOS...
WHAT i have done !!!
1. I have removed the CPU and found some bent pins, I have line them up -*hopefully properly*
2. I have replaced some capacitors on PSU (since some of the lines where it should be 12v, it read 10v, after changing the cap, all readings are fine..
Im still stucked with computer LOOP (no POST, no BIOS).
P.S I have tried almost everything I now, removing everything from MB, but what I can not understand is..???
When I remove CPU from motherboard and power it up, it powers up and stays up, but when I put back JUST CPU, and power it up it goes in looop.....
I have tried CPU on another MB and it worked !!!
So am confused now...!!!
Could it be that as soon as I put CPU on MB it start's looping my PC ???? , or could it be as soon as I put my CPU bios chip (*presume it;s coruppted it tells to a MB not to BOOT cause theres something faulty going on???)
Thanks for all the help !!! in advance...
Spec:
proc: q6600
GPU: 8600gt
