- Aug 1, 2008
- Los Angeles, CA
I just built my new rig with this board and an E8600. Everything works great except something weird is happening with the Bios. Some of the items that are supposed to be in the Bios (according to the user guide) are not there. For example, under the advanced menu the Speedstep technology setting does not appear. So I cannot disable it. But C1E is there. Also I cannot see the list of sata drives in the main menu. Although I was able to raid0 couple of sata drives and I have two more connected. They just don't show up under sata list. They do show up under boot priority though. The Bios seems to be new (June version). It detected the CPU specs correctly. Overclocks fine so far. I am priming at 3.8 at stock volts.
Any helpful thoughts are appreciated.
