I want to set up my air system in my tower. I am aware of my temps so I dont need the programs for monitoring temps. I am using this MOBO http://www.asrock.com.tw/mb/overview.asp?Model=870 Extreme3 .
It has 5 plug ins for fans , 2(1 CPU) of them are 4pin and the others are 3 pin. I have enough room on my tower for 5 regular fans, might add some "slot" fans in the back some time in the future. My main issue Is I want the fans to run automaticly and unless I am missing some thing they wont run automaticly. I would like the fans to slow when the temps are down and speed up as the temps increase until the temps are back down. I dont want to be messing with the fans and temps. Right now my MOBO stays pretty constant at 85F and the CPU when the temps rise and fall I have to adjust the fans according to the heat, is there a setting on the MOBO to monitor this? What are my options? Thanks
