- Oct 4, 2002
- Eugene, OR
Yeah, started writing my post before I saw yours, getting distracted by work ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
those would be good and here are some more choices... still with in you $$ is this ddr2-800 sticksdja2k said:Okay will stay away from the PQI memory. How about this OCZ http://www.newegg.com/Product/Product.asp?Item=N82E16820227047 memory?
dja2k
pscout said:If all else is equal, the allendale will consume less power and produce less heat. IF they are close performance wize for what you want to use them for, then i would definitiely go allendale.
bignick said:Remember he is going to be using this computer for video editing. Netburst is faster than CD2 at encoding.
greenmaji said:Its only equal in video editing performance with a stout overclock then the C2D has a mild. IE no its not better.
And the E6400 will be less FSB limited on the GA-965P-DS3
I dont know what budget ram but you have to run 1:1 so you'll need it to run DDR2 800 and to overclock the quetion would be max frequency timings and Vdimm "what timings and as much as I can give it"![]()
dja2k said:To this point, I am running stock for one primary reason. This friend lives really far from me and if he has problems with the overclock, lets say, it resets, he won't know how to fix it. That is the primary reason.
dja2k
rainless said:And if you get a big video card and have to give up a pci slot...
