rainless said:And about the whole 950/E6300 at stock speeds thing: http://www.tomshardware.com/2006/07/14/core2_duo_knocks_out_athlon_64/page15.html
yea c2d is a monster compared to netburst. well the only reason i am agianst stock hs's is they can get loud when temps start getting high. was just a suggestion though. you know he will be happy with it then if it is busting you p4's knee caps.dja2k said:Well if it was up to me too, I would put the best heatsink, but that is not the problem. This friend of mine is such a cheap skate and gave me a tight budget. Don't know if you remember how I was trying to save money here and there with the help of you guys at the start of this thread. So screw him, let him stay pure stock right now. He'll be okay with the stock heatink for now wouldn't he? Oh well, I will tell him though. Anyways thanks. As I said, its pretty speedy and don't know how the temps go, but idle at 42'C and saw only 55'C with dual prime95, but that isn't real processing per say when encoding video or playing video games in the real world. I did have the stock voltage at 1.325, don't know if that is high for stock. The memory again is at +.1 = 1.9 voltage. Don't know if I had to change the pci frequency stuff for stock and also, the timmings say 3-4-4-12 instead of 4-4-4-12 on cpu-z. Still passed over 10 hours of memtest and over 10 hours of dual prime95 (maximum heat) and so far 5 hours of prime95 (blend test). This core 2 duo makes my pentium 4 cry.
dja2k
dja2k said:Does it adjusts itself because I have not seen it get loud at all.
Joeteck said:Thats freakin awesome!! An AMD FX-62 (2.8Ghz), is slower than a E6600 (2.4ghz). Sweet. Its about time Intel!!!
the normal setting in that board would be 1.8v. i think the key combo was ctrl+F1 or ctrl-F2, its in the manual.dja2k said:Okay guys, I built a second computer for another friend with the same e6400 cpu and ds3 motherboard. I flashed the bios to F5 and now I forgot the basics. What was the option to make more things appear in the bios? Also with the corsair pc26400, am I suppose to up the voltage on the vdimm, if so how much, last time I set it to +.1 giving who know, but now that I look at it, this ram wants 2.1volts, so how much should I + the voltage?
dja2k
