looks good! you made sure the ram you getting is the 6400-c4's right? dont get that 6400 stuff from them that has 5-5-5-12 timings.dja2k said:Here goes my built system...
CPU Intel e6400
MOTHERBOARD Gigabyte DS3
MEMORY Corsair XMS2 2x1024 DDR2 800
CASE Thermaltake SOPRANO VB1000BWS
PSU OCZ 520 PowerStream
VIDEO CARD Saphire X800GTO 512MB PCI Express
HARD DRIVES (TWO) Seagate Barracuda 7200.10 320 GB 16 MB Cache SATA II
dja2k
greenmaji said:His max stable overclock would be higher if it was a E6400 bignick.
by over 400mhz
His max SPI1M clocks are impressive however.
his ram is holding him back as well.. and that wouldn't be near the problem it is if he had that extra multi.
Evilsizer said:looks good! you made sure the ram you getting is the 6400-c4's right? dont get that 6400 stuff from them that has 5-5-5-12 timings.
you mean oc on the cpu or ram? the ram might be able to do ddr2-1000 @5-5-5-12. im currently in the middle of testing mine on the rig#1 since i finally got it setup.dja2k said:Yep got these http://www.newegg.com/Product/Product.asp?item=N82E16820145034 Okay with the e6400 and this ram in the link, for future purposes, what kind of a overclock am I looking at, of course with a better heatsink then?
dja2k
bignick said:All he was saying is C2D is faster if both netberst and C2D have mild overclocks C2D wins. Netburst is only faster if it has a max overclock. I've seen all I need to see that at least stock vs. stock E6300 is the way to go. The only plus with the 945 combo is MUCH cheaper.
with the right board e6400 can hit 3.2ghz... if the board can do better 3.4ghz can be had on a e6400. the fsb of the motherboard is holding back the cpu.dja2k said:Cool about the ram overclocking, but you saying the cpu won't overclock that much right ?
dja2k
Evilsizer said:with the right board e6400 can hit 3.2ghz... if the board can do better 3.4ghz can be had on a e6400. the fsb of the motherboard is holding back the cpu.
yea if you check the model number listed by newegg it says at the end 6400-c4.dja2k said:Hey Evilsizer, that ram I posted earlier, was it the right one?
dja2k
well your in texas to, how about dinner some time?dja2k said:Okay system has been ordered for my friend. Now I have to go collect $2,000 making me $400 profit for building it for him. There is no way we can have a pizza party in this forum, is there? Anyways, thanks all of you for the great help today, would have been lost all the way without you guys.
dja2k
