FTFYHonestly though, you won't notice the difference for the risk of stability by going from 3.5GHz to 3.5+GHz
I have not seen any reports of it killing a mechanical hard drive.
Corrupting data, absolutely. Killing? No.
I have seen (quite a few) reports of it killing the already fragile Sandforce based OCZ drives. Also plenty of reports of it corrupting data on SSDs.
Run Cinebench on all four cores, then try it again when you (naively) cut one off.
You're loading all cores, you'll be surprised how much you lose for want of 1x multi.
You also won't notice the difference of 3.3GHz to 3.5GHz.
Not worth stability issues for a daily usage machine.
Then get HWBot Prime.
Seriously though, first world problems.
Last I checked FAH and Mining on your CPU would be multicore.
Games are ramping up core usage by the week.
I'll give you a hint, 75% of that.
When do you get your bandwidth back again?Which leads me to believe it is better to have a bunch of slower cores than a few faster ones. Right?
Being serious, it depends (and has been discussed ad nauseum on forums, including this one) on your uses. FOr folding, surely more cores for the little difference you get. For other things, you need to test.
Yes, as in, what were your clock speeds set at...
here is what i would do... blk = 100 turbo's set to 31x call it good. or if u wanna go badass then disreguard turbo and turn the multi up to 31x.
Was it the same speed for the first run?
Yes it was.
Something's not right?
You JUST said that you can only set 33X for all four cores, that's what's not right.
No. I have always had all my cores enabled.
Okay, one more time
Here's my cpu multiplier settings:
1 core enabled ---> 35x multiplier
2 cores enabled --> 34x multiplier
3 cores enabled --> 34x multiplier
2 cores enabled --> 33x multiplier
Today, I decided to DISABLE 1 core to get a multiplier of 34x.
But since the multiplier is higher, I get a higher turbo-frequency 3.5 Ghz.
