Which is why I asked if the two runs were the same speed!
You said yes, but I'm assuming the real answer is no.
Incorrect. BOTH test ran @ 2915 Mhz +- 1Mhz.
What did CPUz show while the tests were running?
Was that during the Prime run, or before/after?
During.
The multi usually stays at full anyway. Unless It idle of course.
So, since you got the speed up as high as you can with the three cores and still lost performance, your theory of 1x multi more being better is pretty well trounced.
Honestly, leave the bclk at 100, crank the turbo multi, turn on all the cores, and leave it.
+1 i didnt know this.. but you can just set the multi on that chip to x35 multi full time, no turbo about it. i was thinking 3.1 for some reason..... blk = 100 multi = 35 that is 3.5ghz 24/7 no this core that core many core how core just 3.5ghz.
Well if it matters, the board was still on, and the monitor was giving out video, I was able to tell it froze because I heard buzzing from the headphones.Cutting to off like that typically points to PSU, not unstable overclock.
nvm just turn the turbo multi's up as high as they will go leave blk at 100 call it good.
Same PSU used in the mobo that died, but I tested the rails and they had proper voltages....
Will do.
With 3 cores @ 103.5 Mhz BCLK
Side note: Got that new laptop screen for the laptop I got with the "broken motherboard"
