- Nov 1, 2003
- Thread Starter
- #21
larva said:It's your list, do what you want. But to really make it anything special you need to move beyond a compilation of the conclusions of (by you own admission) the rarely adequate testing that appears on the web and move some knowledge into the equation.
I do not knock the TP330 because the spec sheet numbers don't conform to a rule of thumb, I condemn them because I've used them. They blow up. Nothing to recommend there. TP380s don't blow up, but are hard pressed on the 12V line by modern systems.
TP430s are a great power supply, and are only $65 these days (by your link). And no, you can't run 4GHz with them, and I'm guessing you couldn't run 5GHz either. You have to correctly apply a supply before you can knock it for failing. The extra oomph of a TP480 or 550 is recommended, but the 430 is still a useful supply and a great value. A TP430 will smoke a 350 Fortron, no lie.
Again, you knock the Antec SL for value reasons. That alone isn't a good reason. Lots of power supplies are overpriced, but Antec SLs are recommendation worthy should the price be palatable to the prospective buyer.
As far as the Vantec being noisy, they are often noisy in the regulation too. They are simply not designed and built as well as the Antec or (especially Fortron) alternatives, and do not perform as well. If you can in any way knock a SL antec because of the alternatives there is no case for a Vantec, even if they appear passable in a (isolated) review.
Can you please link me to a review using real tools that shows me that Vantec psu's are bad? I'm not saying I'm not wrong, just that I have seen very convincing REAL numbers that suggest otherwise. And for your comment about the review being isolated: do you know why it's isolated? Because there are only about FIVE, yes FIVE websites that are qualified to do a real psu reivew, silentpcreview.com being one of them. Here's how a real psu review should be done
http://silentpcreview.com/article148-page1.html
So in effect every single good psu review is going to be isolated.
I do have to disagree with your comment about the tru430 smoking the fortron 350 however. On paper, maybe. Howver, you obviously know a lot about psu's, so you must know that Fortron has been proven again and again to underrate their lines and wattages by around 35-30%, and also that Antec's power ratings are taken at a vastly unrealistic 20C for the internal psu temp. How many people's room ambient temps are 20c? Not mine, I know that. At a much more realistic 40C, the antec 550w only produces around 360w. So I seriously doubt that the antec 430 would smoke the fortron 350. Especially when the fortrons are much better built inside. They just don't look as cool. And here's an experience from a very respected and senior forum member at hardforums, xtremesystems.org, and IIRC he's also here. His experience with the Antec 550 and the Fortron 350:
funny thing is, the fortron 350 will handle it all by itself, i tried it, i just didnt want to push the little thing or kill it. I ran the vapo, pelt, Mem @ 3.55v and a Vmodded 9800pro.
Thats what sold me on fortron lately. I started buying them to replace customers cheap PS, the were a good deal for the 300 and 350 watters, under or around $30, plus good reviews on them everywhere. I never expected them to be so heavy.
All i do know is my fortron 350 holds and has better volts in my sig rig than a ttgi550 and antec true550
his sig was a 4.2ghz p4 on a vapochill, vmodded radeon 9800 pro on a pelt running off the psu, 1GB memory bh5 @ 3.55v with his 3.3v line @ 3.7v, etc, etc. ANd he had it running for the longest time until he just upgraded to a64. His 12v line on the antec 550 was drooping to 11.5 under the multimeter during load. The fortron stays right up there. And it has adjustable pots. And Tedinde will come in here and verify everything if you want.
Nuff said.
