- Sep 8, 2004
Yes, sticky this. I really don't know why it hasn't been as the info seems to be good.
CONCLUSION
The Enermax NoiseTaker 475 frankly surprised me. I was not expecting anything special from this model, jaded as I am with marketing hokum from any source; Enermax spreads its share of such hokum. I certainly was not expecting 82% maximum efficiency, nor low-noise operation to 200W and beyond. Both of these qualities are enough to immediately put this model among the Recommended PSUs. Add the high stability and high power capability, and it really starts to look like... something special?
It's true that the ATX12V V1.3 PSU Guideline calls for higher efficiency than before, but the numbers — 70% at full load, 60% at typical load and 50% at light load — are nowhere near what Enermax has achieved here.
The protection circuitry works well. In truth, it would be amazingly difficult to build a desktop system that could demand 470W from the PSU for any length of time. Thus far, the highest power draw I've seen is with an ARM Systems P4-3.2 dual SATA drive PC, which only demanded 235W max in AC power. This NoiseTaker was drawing 600W in AC voltage before the protection circuits shut it down.
This is not to say the unit has no flaws.
The bunched cables may be tidy and nice looking but ye gads, get those girdles off! They could be a real struggle to manage in a real system. Even Ralf Hutter's cabling skills may not be enough here.
Then there are the fans that clatter at low speed; they really can and should be improved. Yes, the usual swaps with quieter fans will make real improvements here, if you can negotiate the tangle of wires inside and are willing to void that 3-year warranty. (The full voltage startup surge should help most fan get started and 3V may be be enough to keep most of them running once they're started).
Sorry to be addressing just the modders and diehards.
Even without any modifications, the Enermax NoiseTaker 475 will be useful and important for people who want to build high power systems that still run quietly. It may not be the quietest PSU at idle, but at 200W output and still just in the low-20s dBA @ 1 meter, it is tough to beat!
It would certainly be interesting to look at the other models in the NoiseTaker line. If that >200W fan speed ramp up point remains unchanged, the lower power NoiseTakermodels would be of great interest to SPCR enthusiasts
Sleepyone said:Well only time will tell, will get back with you in a year if it stops working. But really big is not always better. Just because it looks big dosn't mean it dosn't have cheap parts in it. Using a Fluke DVM isnt what I would call a good check for the long run. Lets face it if you look at most items made for home pc, they all look cheap. If you can take a look at items made for big aircraft or items that cost 100k a pop. Then you can get the idea of what its all about.
go ahead, buy a deer psu and put it in your machine, and leave it running prime 95 overnight. I dare you See my point?
Oklahoma: thx for the link. added.
Daewood said:personally i do not think this should be a sticky (even though you took all that time to write it up and revise it) because what is bad for some may be okay or even great for others.
take the ultra-x connect some have had troubles and others love it...
another is the raidmax, although they are not good with overclocking i think that they are just fine for budget cases that comes with one.
that is just my .02 and i think the only way this should be a sticky is if you change the words "Do not buy a psu from the following companies !!!!!!!" to something along the lines of "i recomend staying away from this psu because they have a reputation to go out and take compys with them"
Daewood said:i was just saying for people that just go out and buy a raidmax case and it has one of them in it if they are not overclocking or using 80 fans then they are fine until you can afford a good psu
Daewood said:well my raidmax has not died with my 1.8 celly for 2 years but i do agree with you about a good psu like TTGI, Fortron, PC Power & Cooling, or ocz for a very stable and reliable PSU...
Evilsizer said:Now i'm about to order this psu from zippy. I dont understand why this one isnt on there even though there are two 600watts from zippy on the egg. This one linked has 2x12v lines 46amps total.
