Thanks though I read that Internal PLL Overvoltage is not needed unless you're going for higher OCs? 4.5+? I bumped up LLC to level2 from level 3.
Current settings:
Firing up prime95 torture test for a bit.
somegeek
I tried my I5-2500k and Asus P8Z68-V Pro/Gen3 on 4.5 last night.
During the Intel Burn Test it hit 87-89 degrees on 3 of the cores. I went ahead and stopped the test. From what I gathered this is too hot right even for the test right?
sorry yeah i have
MB Gigabyte GA-Z68XP-UD3
Cooler Enermax ETS-T40-TB CPU Cooler
PSU Thermaltake 750
Memory Corsair Vengeance 8g
HDD Corsair Performance SSD
@ the moment my OC 4.3 is @ 1.25 Vcore
when trying the 4.5
1.35 Vocre ( have tested from 1.30 to 1.39 )
1.150 QPI/VTT
1.100 Graphic Core
1.815 CPU PLL
1.510 DRAM i get the boot but not entering windows i have alos tried
LLC @ lvl5
also i have tried these settings
Vcore = NORMAL
DVID = +.050 (when Vcore was set to NORMAL)
QPI/VTT = 1.150
PLL = 1.815
so i have tried all these setting with no success to OC to 4.5 just boots with windows failing
Cpu cooler? Case? Are you sure fans are on max? CPU cooler is installed tight and properly? 87-89 sucks. It's not damaging suck but it's suck. I'd draw the line and pull the plug at 90 but again, if you pass the IBT and P95 you have to keep in mind actual use temps will be lower. If your CPU cooler is infact installed properly it'd be wise to go to a higher quality one but again, actual use is maybe 65 or that area even though ibt is 87 and p95 is 80.
I believe the force is strong with that one.Really ED? What was the tempraturs like? I figured that kind of load was outside the 212's thermal envelope given the 2600 runs hotter. With enough cool airflow you can do anything though. I had a 3 degree idle on my E6550 with 32F ambient last winter.
With a yate loon high on high I could bench there no problem. 4.5ghz 24/7 was easy and not noisey. Ambients were 19/20c.Really ED? What was the tempraturs like? I figured that kind of load was outside the 212's thermal envelope given the 2600 runs hotter. With enough cool airflow you can do anything though. I had a 3 degree idle on my E6550 with 32F ambient last winter.
I've had p95 blend going for about 2 hrs now and looks like 76 deg is the max temp on the hottest core.
So you don't think I need a new case?
