- Sep 20, 2010
+1. That is what I have done and works quite well.. the .5 to be specific, LOL!In the past I have used a mechanical pencil with no lead in it , and stuck the pin in the end where the lead comes out and used that .
I managed to bend a pin on an Intel P67 mobo, ironically it happens when I remove the plastic pin protector cover on the socket. It was bent pretty bad so I broke it trying to fix it. Oddly mobo works fine . Perhaps its a pin for the on die GPU? which I don't use.... it's a 2700K btw. I even did a simple overclock to 4.5ghz by just adjusting the turbo boost to 45, no ill effects so far.
