So the problem im having is my gaming laptop though used seldom for dedicated gaming will get very hot due to this being a MSI Gt60 whitebook debadged and limited bells and whistles. It only has one heat sink shared between the CPU I7-4700MQ and GPU GTX 880m. The GPU gets 90c even with the fan maxed out, though i have bought a external vacuum fan with better results keeping it in the 80s. But the CPU stays in the 70s with stock fan and 65-68c with vacuum fan no problem. The GPU heat sink is connected to the CPU heat sink with a thermal pad and i feel this is where im loosing some of the cooling capacity.
So my question is what is the best brand of thermal pad i can get, or is there another solution that i could use to help transfer heat to the heat sink?
BTW the only reason i bought the whitebook version i got it on clearance from a PC store online for $900 off retail price.
Thanks all for the info,
Shadow
Shadow
