- Feb 19, 2003
- New York
Very cool Thanks will try now.
Harry
Harry
Hey try the patch script in the new year edition of RT that should work? or i could send you a copy of my patched bios.I have the same card as you.Also you might wanna get an NV5 because i did and it improvemd my temps big time went from idle 60c to 39-41c idle and never goes over 54c now.harryinny3 said:Ok, I did everything in the guide to Hard mod the Pipes. Didnt work. saved my bios and Tried the adding the script, and it wouldnt add. Why i dont know.
Anyhow, Is there another utility that will tell if the Pipes are open? I see 3dmark03 doesnt give that info. Ive seen a good Performance gain in games. Theres No artifacts at all. And the mild overclock is great.
How far can a 6800NU go on memory? Just curiouse. I use to be a diehard nvidia User, But went to ATI during the whole FX Deal. Now im back to Nvidia and Love it. But as i say, my money goes where the Better Bargain is. And ATI doesnt have ANY bargains for same performance at this time.
Harry
CandymanCan said:hmm ok i'll call them up and see what they say about the noises and RMA. Do i need to erase the HDD before i RMA it
I realy don't think that this card can go any higher it seems to but then when I go to benchmark it I get a way lower score than if I leave it stock. at any rate I used all the short cuts and tryed every thing that was listed to no avail what is it? a bad card / not O/Cable? wierd since it is a PNY 6800GT one would think that it is O/Cable but like I said it don't like to go up..g0dM@n said:There is another program other than the nvflash... try using the other. Look at the first page. I'll help you when I have time... I've just been really busy with work/girl/gym... etc...
I think that it's called VGAbios or something... just find out... there is another vga bios flashing program other than nvflash. Are you using the shortcuts too? (i.e. -p -u)
What's going on is you are pushing your card too hard <most likely on RAM>. Since PNY uses crappy fets you powerstarve your board cauing that stuttering effect.trickson said:I realy don't think that this card can go any higher it seems to but then when I go to benchmark it I get a way lower score than if I leave it stock. at any rate I used all the short cuts and tryed every thing that was listed to no avail what is it? a bad card / not O/Cable? wierd since it is a PNY 6800GT one would think that it is O/Cable but like I said it don't like to go up..
no I dought it is the mobo DFI is too good .. yeah I figured that there has to be a video card problem that wont let it O/C oh well too bad for me I guess ...Sentential said:What's going on is you are pushing your card too hard <most likely on RAM>. Since PNY uses crappy fets you powerstarve your board cauing that stuttering effect.
Could also be a motherboard issue since my AV8 no longer does that when my K8N Neo2 did.
that is what I have feard . so what do you sugjest I do? should I get the 6800U O/Ced? what manufacturer should I go with? need your help PLEASE.. Thank you Sentential...Sentential said:What's going on is you are pushing your card too hard <most likely on RAM>. Since PNY uses crappy fets you powerstarve your board cauing that stuttering effect.
