QuietIce
Disabled
- May 7, 2006
- Anywhere but there
Go for it ...!
Go for it ...!
Was beginning to wonder if it'd ever get stable. Found out this board under volts what it supposedly puts out. When set to 1.40v it actually (according to CPU-Z) puts out 1.38ish so after bumping the voltage on NB slightly and the vcore very lightly as well it seemed to push through.
Load temps seem to be staying between 50-51C which is better than I'd expected, I could work with that and video games.
What do you mean it went out? Did it shutdown and you had to press the PC case start button to start it back up?Still havn't gotten a fully stable run out of 3.9 the ten minute test went nice but 22 minutes in it went out. I was so tired though I layed down for bed, I'll work with it tonight I have the next couple days off and it's going to rain Labor day so no plans for a BBQ.
I'll get back in touch tonight maybe you guys can help me out a bit. I'm re reading through Dolk's guide and doing general research on HT Link and such to get a feel of what the certain options will do to the clock speed. AMD may be harder to over clock but I still find my purchase very worth it.
Well gentlemen I'm off to Red Lobster it's my grandmothers b-day and that's my present to her
Knock on wood but good to hear ...It went out as in BSOD... there are no more spontaneous restarts at stock settings nor at stable oc's anymore.
You could do the same thing (actually better!) with a couple of 1x heater cores and a copper 'T' from the hardware store ...Check THIS beefy H50 out
It wasn't the thickness I was talking about. Modern water blocks often have a slight bulge in the center of the sink (convex base) and it's on purpose. When you bolt down the block the base is thin enough that it gives slightly so once it's in place the base is actually flat. Having the bulge puts a little more pressure on the center of the CPU for better heat transfer in that area, which is where every CPU is hottest. It's worked very good on the custom loop blocks and, if the H50 mount is strong enough and the base thin enough, it should work well for it, too.Actually you make a good point the H50 it's self only mounts tight once you start to screw in the bracket so it makes sense that filing down it's surface would cause some compression to be lost.
Reasoning for brining it up was someone mentioning in a different from via Google that you can experience (keyword) anywhere from 2C-5C less in temps, same thread mentioned the method of pea sized tim and allowing the cpu to press down and spread the tim which I personally don't believe in I'd think allowing the HSF to do the work would cause less tim to cover the cpu leading to less significant heat transfer.
Thanks - I'll check it out ...YOUTUBE VIDEO believe it's about 5 parts long it's pretty dang cool
