im jelly
I almost feel ashamed to ask, but, is that trapeze really safe? You surely wouldn't want the PSU to fall on your RAMs...
Hi, I'm Peanut Butter. Wanna get together and make a sandwhich
Dont want it to fall on anything, why is it secluded to only the RAM lol
More importantly, how is the PSU secured in the trapeze? If its tight, its not coming out... I don't think its just balanced there.
Oops sorry didn't see all the trapeze discussion.
The vertical components are 4 pieces of 6-32 threaded brass rod. The brackets are 3/4" x 1/16" thick brass angle with some cushion rubber. The threaded rods are threaded directly into cross bars, then secured under the angle brass with washers and thumb screws. The thumb screws tighten up strapping the PSU in as tightly as you want it.
I would say the weak point would be stripping 6-32 brass rod. With 4 anchor points it can without a doubt hold any psu.
