- Aug 27, 2012
When i did my test boot i realized my computer would just start up and turn of after a few seconds. I realized that some of the Pins were bent on the LGA 1155 socket. I called my friend who specializes with computers and he tried to unbend those pins. Doing so, he bend more pins and he broke one. He even dropped my CPU on the floor ( not from a high distance ) He said its ok to try to boot it up again so i did. I already ordered a new motherboard because i know the warranty doesn't cover bend pins. I was just wondering if test booting my motherboard with the bend pins damaged my CPU. I read somewhere that if those pins make contact with the wrong golden pads on the CPU it may damage it. Should i return the CPU and get a new one? Or do you guys think i'll be okay?
Specs:
Motherboard: Gigabyte Z77x-UD3H(bend pins) Upgrading to a Asus Z77 sabertooth
Hard Drive: 1 Tb Western Digital Mechanical Blue
SSD: 240gb Sandisk SSD
Graphics Card: Gigabyte Gtx 670 Windfore OC
Ram: 8gb Crosair Vengence DDR3
Optical Drive: Asus 24xDVD-RW Serial ATA Internal OEM Drive DRW-24B1ST
Case: Cooler Master HAF 932 Advanced
CPU: Intel Core i5 2500k
PSU: OCZ ModXStream Pro 700W
Specs:
