I can not get my 3200 Winchester (CBBHD 0447UPEW) with the system in my sig to run any type of overclock stable, not even 2200MHz. At stock clocks its 100% stable. But any type of CPU OC and its BSOD's all over the place.
And the CPU does not seem to respond to voltage at all, doesn't make a difference if it’s at 1.36v or 1.6v, the chip will not run stable when it has any type of OC. Though at voltages over 1.55v it seems to make it even more unstable. Temps accroding to corecenter are 37-40c idle and 45-48c load, though I think they are way off.
I currently have the system running at:
275x7 (1925MHz) 3x HTT / 1.36vcore (Bios 1.5x) Bios 1.4 had the same performance
Ram @ 2.5-3-3-10 1t 1:1 @ 2.65v
High Performance mode = Manual
Aggressive timings = Disabled
NV/ATI speed up = Disabled
Dram Drive Strength = Normal
Dynamic OCing = Disabled
Spread Spectrum = Disabled
HT Frequency = 3x
Cool 'n' Quiet = Disabled
PCI Clock Auto Detect = Enabled
AGP Freq. = 66Hz (Clockgen confirms that it does stay at 66Hz)
AGP Voltage = 1.50v (Tried 1.5v to 1.6v and makes no difference for the CPU OC)
That other menu:
AGP APP Size = 128MB
AGP Speed = 4x/8x
AGP Fast Writes = Disabled
AGP Side Banding = Disabled (Though CPUz shows it enabled in the MB tab)
And so far it is 100% stable. At these settings it passed 10hours of prime95 a few times. Games and 3dmark are stable and it passes 10 hours of memtest86 with 0 errors and passes every SuperPI test fine.
But as soon as I bring the CPU Multi up to 8 making it 275x8 (2200MHz) it is unstable again. The first time this happened I figured ok it needs a little more vcore, even though I didn't think a 200MHz increase would need more vcore I tried it anyway. But raising the vcore from 1.36v all the way 1.5v testing it in every increment in between made no difference. It would still only pass a few hours of prime95, BSOD once in a while, and SuperPI would error out once in a while. (Though at 272x9 (2448MHz) I got it to pass 10 hours of memtest86 with 0 errors, but still not stable in windows)
I tried OCing with a higher multi/lower FSB before all of this also, It doesn't seem to make a difference
220x10, 240x10, 250x10, 275x8, 275x9, All of these settings are equally unstable. 2500MHz isn't anymore unstable then 2200MHz (vcore has no affect for stability on any of it). The only thing that is stable is 2000MHz.
Going by all of this testing I figure that I just didn't get a lucky chip?
275x7 is stable and 275x8 is not, and vcore has no affect, what else can it be? Is there any other settings that would have an affect on this?
I don't feel that it is my PSU because the system is still stable when I have my GT @ Ultra clocks and both of my CCFL's on. Also I'm only running 1 5400RPM pos HDD right now because the BSOD'ing killed my WD 120GB JB drive and I also took out my 250GB JB drive while OC testing so that wouldn't die also.
What else do u guys think it could be? If it is the CPU u'll see it up in the market place real soon
Screen shots of the stable settings....
http://www.matrix.gamingunited.com/OC/1.jpg CPUz
http://www.matrix.gamingunited.com/OC/2.jpg CPUz ram timings
http://www.matrix.gamingunited.com/OC/4.jpg Prime 10 hours
http://www.matrix.gamingunited.com/OC/6.jpg Corecenter
At 272x9 (2448MHz) I got it to pass 10 hours of memtest86 with 0 errors, but still not stable in windows.
http://www.matrix.gamingunited.com/OC/3.jpg Memtest86
HT Frequency = 3x
That other menu:
AGP Speed = 4x/8x
