- Aug 3, 2013
- Toronto, ON, Canada
I am looking for some assistance in trouble shooting a new system I just built. Thought it was all ok, until I tried to power up and nothing happened.
When I connect the power cable, a small LED illuminates on the on-board power switch on my ASUS Z87 motherboard. When I turn on the power switch on the Antec HCP-1000 power supply, this LED goes off. At this point, pressing the front panel power-on switch, or the on-board power-on switch, has no effect. No other indicators are on, and no fans are running.
I am wondering if I have all the necessary power cables connected? There is a large 24-pin power cable connected to the mobo to the right of the RAM bank. The other end of this cable is split into two connectors: a 20-pin conn. that I plugged into the MB socket on the PS, and a smaller 8-pin conn. that I plugged into one of the 12V sockets.
There is another cable that I believe is a 12v delivery system for the CPU, that is plugged into the mobo in the upper left near the I/O panel - the other end is plugged into one of the 12v sockets on the PS.
I would appreciate any suggestions or ideas to trouble shoot this.
One question: will the PS run without load? That is, will the unit's fan run without any of the outputs connected?
Thanks for your patience.. this is my first build.
