im guessing about 10 min.how can i set the time limit to test.
so should i keep adjusting in bios? i am at 16 multiplier now.or should i go to the adjustment that says 1.475 is normal?i have everything disabled now. i just need to know if i should just keep adjusting up until it no longer boots and then back down? if so, what should i adjust my ram to. it says it is at 1.8v.There's no way to do that in Prime95 that I know of. To get a good idea of what maximum core and CPU temps will be you just need to run Prime95 for 10-20 minutes. In that amount of time the max temps will be within about 2 C. of what they will be if you run a much longer test.
To confirm stability of the system, however, a Prime95 test of at least 2 hrs. would need to be run and passed.
Could you take some digital camera pictures of the "Intelligent Tweaker" section of your bios and upload the with your next post? We need to see what you see. On Auto your CPU voltage should be around 1.325. The next step up should not be all the way to 1.475.
yea, i can do that. just give me a minute to set it up. also, the northbridge is in auto. should i leave it there?
