- Apr 5, 2012
- Malaysia, South East Asia.
Guys, usually the clearance between the CPU Cooler / CPU Cooler FAN and the RAM. What is it based on ??
The type of CPU Cooler you use , or it's the type of Motherboard ?
Im planning to get a Corsair Vengeance RAM but problem is the RAM is high as hell , from the looks of now , im using a normal RAM , so its fine , but my CPU Cooler FAN , its just sitting directly above of my RAM now !
How do I know if the Vengeance RAM could fit ??
But im only be using a 8GB Kit , so its a 2X 4GB , currently i had my RAM install on channel " A " , the other 2 channels left are " B "
So if i had my RAM install on channel " B " it will definitely fit ! But thing is
Can i install on channel " B" instead of " A " , since " A " come first then only after " B "
Help anyone ?
Im using a Cooler Master Hyper TX3 EVO CPU Cooler + Asus P8Z77-M Mobo.
Help anyone ?
