- Mar 1, 2013
http://www.john-am.com/2011/01/modding-a-hauppauge-wintv-hvr-950q-with-heatsinks/
I'm actually doing just that on my HVR-850 (which is actually a HVR-950Q without the analog adapter cable) since I'm going to be using it in a MythTV system where it would run 24/7. I used JB Weld to mount a heatsink over the demodulator and USB chips. I also insulated the RF front end (except for the top of the tuner chip) and put a piece of copper tape over it, soldered the tape to ground (shielding enhancement since I'm planning on putting it inside a PC case), and attached a heatsink over that with JB Weld.
