Which would cool a 3770k better?
Corsair H100 push/pull config, 2x 120mm on bottom, 140mm and 100mm on top.
Noctua NH-D14
-IF I were to get the Corsair H100, should I keep the 120mm fans or change them? What 140mm fan should I get? What 100mm fan should I get?
-IF I were to get the NH-D14, is it possible to add another fan to it?
-IF I were to get the NH-D14, should I keep the stock fans or change them out? If you can fit a third fan, which fan should I get for it?
Noctua NH-D14
