- Sep 15, 2007
- Small town Emlenton, PA
H series H100 you mean, no other is able to barely beat top air.
Yeah you have all reason on this is second hand knowledge.. But I help him to install all that system and I help him make the clocks in him processor.. when I told you.. Is the first time what I work with a water cooler.. but my opinion is what is a great cooler and you need respect this ok?
If you work with this same system and you have bad experience I respect this.. If u never have this items in your hand.. And your only reference come from wc forums.. post with more respect.. I have more than 7 years working with OC and extreme machines bro
If I go air, is the Phanteks PH-TC14PE the best choice as of July 2012?Look, I've used both the H100 and Noctua NH-D14. The H100 is the better cooler, especially with upgraded fans. The Noctua is slightly lower performing however due to my experiences with reliabillity with the Corsair Hydro series I can't really recommend them.
Either go high end air or move to a custom water loop.
How much better would the H100 cool if I used push/pull with 4 fans? Is it worth the extra money and noise?More air better temps. All you gotta do is get 4 great fans with 2000 RPM and it will perform almost as well as a 120x2 XSPC RX rad, Swiftech 35X, good CPU block and res etc. It'll be twice as loud but perform pretty well. And 1/3rd the cost. And 1/100th the reliability.
CM Storm Trooper. Would the Phanteks fit if I were using G.Skill RipJawsX?Yep, the Phanteks is the best currently available. What case are you running? You've no sig so I can't refer to that.
With the Phanteks you can run 3x fans, though it only nets about 2-4 degree's from what I've seen. Not really worth the extra noise.
