- Nov 7, 2005
- Austin, Tx
someone plz tell me what the cheapest pelter and the most expensive pelter would cost and why?
bri1 said:someone plz tell me what the cheapest pelter and the most expensive pelter would cost and why?
yepbri1 said:umm but you would need water cooling components right?
It's also possible to air cool peltiers. It gets tricky for the big ones, though.umm but you would need water cooling components right?
how big do they get the bigest ive seen isDell_Axim said:It's also possible to air cool peltiers. It gets tricky for the big ones, though.
oh hell no. any pelt on a cpu these days would be at least 226W, and the total output wattage is 226 PLUS the actual CPU wattage, which is typically about 80W these days. thats 306W of heat for a piece of metal to dissipate. Intel's big -*** stock coolers can barely cut it on 80W...LabRat23 said:I would say its either impossible or really impractical to air cool a pelt settup for a cpu now. That is, anything putting out more than 50w. An AMD system might be possible but a prescott is out of the question.
LabRat23 said:You need a waterblock. I would suggest one that has its cooling surfaces spread out such as swiftech's 600x series or a maze type of block.
