- Dec 27, 2008
You can go ahead and change the ram speed back to 1066 in bios. I only had you slow it down to 400 because you were talking about seeing how far the fsb could be taken. If you put it back to 1066 with the FSB at 250 mhz then I think that will turn out to make the ram running at 1333 mhz which is it's rated max frequency.
And, yes, you can lower the CPUNB frequency. Looking at your other thread it should be the "NB to CPU Frequency" line in bios which you would need to take off of Auto. Unfortunately, this will also probably lower your HT Link frequency which may cost you some PCI-e performance. What you don't have the ability to do and which is a real limitation is to increase the CPUNB voltage. For now, leave the NB to CPU Frequency like it is. Go ahead and change that memory speed, however, and post back with new pics of the three CPU-z tabs so we can verify the effect of the memory speed change.
