- Apr 20, 2004
- JAX, Mississauna
So what will he really have after purchasing a new motherboard?
He will still have a single stick of 2gig ram. He will still have a single core sempron with a stock cooler for the temps of a country in the hot middle east it sounds like.
The board and processor (145 Sempron ) seem to run at a 500Mhz overclock pretty sucessfully, the best I could tell with all the many threads and jumping around that has gone on.
So he gets some sort of different AMD chipset motherboard and seems still with onboard video which limits him to an older chipset and most of the good mobo makers Asus, Gigabyte and so forth are using old AMD chipsets to cobble together onboard desktop motherboards for cpus that are not AMD APUs.
Then he gets a new motherboard and we tell him you need more ram. You need a newer cooler to overclock.
I wonder if a good suggestion might not be to get a 'real' 4 core Boxed AMD processor and put it in the board he has and the performance would be way ahead of the sempron. I doubt any board will bring a Sempron up to the performance of a 4 core running at its' stock speed of 3.0Ghz or 3.2Ghz if he gets the correct AMD four core processor.
Sometimes I think we get hung-up on overclocking. I tend to do so, but I had to learn otherwise to deal with 'customers' for 6.5 years.
So where is his 'real' bang for the buck? Truth be told it is probably a newer AMD APU setup, but if not then likely a good 4 core graphicless cpu and stock cooler working over anything he could do with a Sempron overall.
