I have installed this small piece of software by mistake. And cannot delete it. I am running WinXP Pro. I installed the software in administrator mode right onto the desktop.
I have no idea how to remove it from my system. It's not listed in Add/Remove Programs, and I can't erase it or delete it. When I try to delete it, I get an error box that says "Cannot delete GhostSurfe Protect Your Privacy: It is being used by another person or program"
I tried safe mode too..and same problem I get as above...There's a PIF file that installed itself too.
If I Right click on Properties for this program, and under the program tab, click on advanced, I get Windows PIF settings, underneath which it says
Custom MS DOS Initialization Files...w/the following lines:
Autoexecfile name: %SystemRoot%\SYSTEM32\AUTOEXEC.NT
Config file name: %SystemRoot%\SYSTEM32\CONFIG.NT
This is all I know..I have no idea how to get rid of this software...
ANY help would be appreciated..
Thanks in advance
Thanks in advance
