Alaric
- Dec 4, 2011
- Satan's Colon, US
The truth is probably somewhere in the middle. It usually is. LOL
Panic...lol. i definitely think they reacted to Ryzen, i hardly think it was in panic.
Isnt it cooler in many cases than open air? Typically, open air has little to no airflow while cases do... i mean of you can run bare vrm with just a fan pointed at it... the heatsink and minimal flow should be ok?
4.6 ghz, no. 4.5 ghz and aida64, yes. I wouldnt have the cooling for p95 avx.
these dont come with a cooler, but i highly doubt that stock intel cooler would work on this past stock. My aftermarket solution crapped out at 4.5ghz all cores/tbreads, as noted in the review. Not sure what point im making of yours, however.Stock air cooler wouldn't have been enough? Or you didn't even have an aftermarket solution that could handle stock speed stress testing? I'm thinking you're making my earlier argument... but that's none of my business. LOL
The only difference here ( but quite important ) is that he has 4 fans near mobo/vrm ... der8auer said that there are no issues when there is additional fan on the vrm heatsink and issues are when is no additional cooling for vrm.
Ok, so tested again, and saw fluctuations at stock, 4 GHz and 4.5 GHz. In none of these were it because of VRM temp throttling in this situation. At 4.5 GHz after an hour, the heatsink was hot to the touch. If you notice, there was no CPU throttling in the screen shot (though that shows a shorter clip in time than the top temp graph. In this test, my average clocks in the 'statistics' tab, showed 4000.5. Minimum was 3994, while maximum was 4004. HWMonitor is the only thing showing ~100 MHz fluctuations, though....AIDA64 is not showing that at all. Here is a 4 Ghz SS showing the difference I talking about...I noticed in your review it clocked down to 4.422GHz while stress testing at 4.5GHz. Do you think that is borderline VRM overheating?
Its a cheaper alternative. for those that need the threads, its the better alternative. Otherwise, if you want the best IPC, you need to pay for it.I don't think anyone but Intel and their stockholders cares "why". It's a huge increase and Team Red is effectively putting the screws to Intel. "Why" is a distant second place to the fact that consumers are spending money on AMD and not Intel.
