The only difference here ( but quite important ) is that he has 4 fans near mobo/vrm ... der8auer said that there are no issues when there is additional fan on the vrm heatsink and issues are when is no additional cooling for vrm. If I'm right then there is issue with contact of heatsink as there were comments about bad heat transfer between vrm and heatsink on other boards like gigabyte series.
One more X series on which Intel was saving. Each Intel X generation is not as good as it was planned. Every generation has some issues. Somehow barely anyone is talking about it. When AMD has issues while overclocking then whole internet is shouting.
X58 = vrm issues, most motherboards had problems under full load, MSI, ASRock and Biostar boards were simply dying ( don't read it as most popular OC boards which were actually good but were also redesigned after premiere )
X79 = design flaw, some controllers were disabled because of stability issues, delayed premiere because of stability issues
X99 = SAS controllers were disabled, PCIE lanes were reordered, delayed premiere because of stability issues
X299 = power delivery issue, premiere faster than expected but they could spend some more time to release fully tested product
In the same time all X series motherboards had issues with memory slots ... sooner or later memory was not visible or capacity issues were happening. I wonder if the same will be with X299 boards.
