- Jan 12, 2012
Zip tie the wb on
Well the proof is in the pics. The new bios helped managed to get the GEIL over 250 but loose timings. The one place it really made a difference was in Catzilla. about 10% on the score. Thanks for your help Scotty, I appreciate it. I think I'm going to have to set this up in the garage. No heat out there and I'm using an FX8350 cooler on it ATM since I don't really have anything else that fits the stock AMD bracket. WB won't accommodate the 2 hole set-up either. So 2800 ish is about as far as I can go.
+1, yeah don't run 4 sticks if you're benching it, only if you're using it at a 24/7 stable OC. I ran with four sticks in my SLI-DR Expert for 4GB, but I didn't have a very aggressive overclock on it for regular usage as a backup PC.As a former DFI Street member and one of Rgone's sidekicks I can probably help you out.
Use your resources.
4 sticks is not what you want to bench on 939 let alone DFI. Very picky boards.
The right bios is the key, and there are about a billion of them.
Picky ram board. Need to use the right slots pending the type of IC's.
Battery NEEDS to be 3v, no less, and it'll suck batteries down like there's no tomorrow.
Ask specific questions and I'll do the best I can. For all the modded bios's, you know where to go.
I run a couple different sets of Kingston BH-5 without issue, so don't let that scare you. I can go cas 1.5 to well over 250.
Temps for 939 are pretty much limited to 50c. Obviously colder is better.......to a point. Much CB and CBB to be had.
The proper Clear CMOS recovery. Not to be confused with a Normal CMOS Clear.
You can not use a USB keyboard for this procedure. You must use a PS2 keyboard.
You will need your manual to find the jumpers that must be changed.
If you skip or miss any step you must start again since the results will not be valid.
Remove power from the rig by pulling the plug or switching the PSU off.
Move the PC Speaker jumper to the ON position.
Remove the Battery.
Move the CMOS jumper to CLEAR.
Press the Start Button on the case or motherboard to drain the capacitors.
You may leave the board in this condition for as long as it takes to clear the CMOS. If a short 30 second clear or a 15 minute clear doesn't work, try an 8 hour clear.
Plug in a PS2 Keyboard.
Put one stick of RAM in the slot marked DIMM2.
Move the CMOS jumper to Normal.
Replace the Battery.
Press and hold the Insert Key on the Keyboard.
Apply power to the rig by plugging the power in or using the switch on the PSU.
Press the Start Button to power the rig up.
When you hear the BEEP, release the Insert Key and press the Delete Key on the Keyboard.
Once you enter the BIOS set the DATE and TIME then Load Optimized Defaults.
Save and Exit.
Enter the BIOS again and set it up the way you want for your particular rig.
