Thanks for the reply,
True on the round tube rads they use on every end of the tubes an o-ring judging from the pictures i have seen from the inner workings of the AMS rad. I also skimped through various foreign threads regarding the AMS rad that are indeed one of he most cleanest rads out there. Not to say one has no need to clean them infact i will clean them flush them with warm distilled water and some sysclean-hpd. Will do also with the EK-ZMT tubing cleaning that is. Hopefully this rad won't give me issues regarding gunk even after i flushed my rad properly (conventional flat tube rads) it might over time still contain crap that ends up in ones loop. Clean system for atleast a year before i tear it down for maintenance.
As some have asked regarding overclocking yes im planning to overclock my upcoming i7-6800k it seems that 4.4ghz on those cpu's is max according to feedback. Same but not sure on the gpu...gonna have to see if i actually need to o.c. the gpu, which i doubt i will...and the possibility of SLI setup...
True i made a mistake about the thickness of the radical 4 rads in comparison with the Alphacool Monsta rads.
No longer will i use two of those rads and just ordered a single Aquacomputer AMS 840 full copper rad (6 x 140): this one has 2 circuits the one ordered is single circuit btw.
Talked to Sven from Aquacomputer prior to ordering and asked him if the rad could be free from imperfections like bend fins etc so he offered me a custom build with no additional cost only downside is the time approx 2 or 3 weeks before receiving the rad.
After my mistake with the 360 Monsta rad cooling cpu and gpu i went ahead and got my self a bit of an overkill radiator but this should offer me the headroom for overclocking or sli setup and silence running 600rpm to 800rpm fans to which this rad is optimized for.
Indeed the Heatkiller IV basic acetal is one of the least restrictive cpu blocks out there but still cools good. Its not 100% going with that block still doubting between that or Heatkiller IV pro or the upcoming Koolance CPU-390i or even the EK Evo since that one guarantees the use of Bitspower 1/2 x 3/4 compression fittings unlike the Heatkiller IV...that shouldnt be a problem since opting for EK-ZMT tubing with spring clamps from koolance which do look nice for clamps:
Judging from the tightness of the koolance clamps on ZMT tubing it grips better then any compression i have used.
Going to post temps from stock as well as overclocked for both idle and full load on both cpu and gpu as well as flow chart to see its gpm. If anyone is interested in that...once i have the new rig running.
