True...The problem with this nonsense is that when you remove the solder and use paste, the temps go up, not down. Even LM isn't as good as the soldered IHS plate.
However, you can de-lid these Ryzen chips, use a decent thermal paste, re-install the stock cooler and use the chip like nothing happened. Again, yes higher temps, but slightly.
The only benefit to de-lidding is by running naked waterblock to die. That's where the temp drops come from. Not some fancy mounting garbage that won't bring temps 8c lower even if you pray for it.
True...
However, this product isn't made for delidded CPUs or designed to delid in the first place. It was made to replace the stock amd mounting with a new one aligned to the CPUs hotspot center. This has nothing to do with delidding.
The project started out for delidded CPU's, but progressed into an all around solution for even the lidded processors.
Yep!The project started out for delidded CPU's, but progressed into an all around solution for even the lidded processors.
Shall I send you one?
No idea. I fancy the idea though. Centering the cooler over the hot spot seem logical for a temp decrease.
This looks cool to me. Most water blocks force water into the center of the cold plate first, that extra turbulence as it contacts the cold plate perpendicular would transfer more heat. At least that's what I'm imagining here. I don't think it would do anything for air coolers. Noctua tested the heatpipe orientation and found no difference, I'm guessing again that it is because the heatpipes are so efficient that the easily transfer the heat from one to another.
Every single Ryzen 3000 that I was testing was working fine with a stock cooler ... however, every single Ryzen 3000 that I was testing was dropping CPU clock because of too high temps as in every case it was reaching 95°C. The difference between a stock cooler under load and above average 3rd party cooler was around 100-200MHz for constant higher load work. Hard to call it throttling as it fits CPU's clock range specified by AMD but for sure causes the CPU to run slower than it could at a lower temp.
I still see no point in a special mounting as 6-8°C (as ShrimpBrime said) is not affecting OC in any way unless the CPU is already reaching 95°C. Even then you can set a higher Tj like +20°C (at least on higher series motherboards). Going from a small cooler like Noctua D9L/single fan to U12S helped to OC my CPUs all... 0-50MHz depends on the chip. The difference in temps was around 10°C.
It looks like another stuff full of marketing. The price is ~€30 but have to add ~€15 for shipping to near countries like Poland. Still better than €90 EUR(+shipping) delidding tools.
