CFusion (Dec 18, 2000 05:46 p.m.):
1.5GHz?!?!? You gotta be bullshitting.
BK (Dec 18, 2000 07:35 p.m.):
it will boot at 1050 mhz but locks up when loading windows. i am currently using a regular chrome orb moddified to fit the kt7. i was wondering if a better cooler would increase my chances at a stable 1050 mhz.
Eriksson (Dec 18, 2000 09:24 p.m.):
get you a alpha pep66 , artic silver paste, and try the sandpaper , and I found a good way to get that old silicone heat paste off . Use a little rubbing alcohol and a q-tip. I am not sure if that is the right way but it worked fine for me.
precise answer is yes. 8)
ElectricMan (Dec 18, 2000 10:33 p.m.):
