- Nov 7, 2002
- Syracuse, NY
so, i'm looking to start with just a modest OC to 3.6.
i started with all volts at AUTO settings, linked FSB, set mem ratio to sync mode and changed FSB QDR to 1600 (changed FSB to 400mhz x 9)
when i save settings and reboot i get the post beep but it will not display the post screen. i then turned off the power and let it sit for a few secs then turned her back on... she then boots up to a post error that says it failed to post last time and that i should change settings back to default. i just told it to continue on the error (at that point the post screen said it was at 3.6) but when i get in to windows it states that it is still running at stock 3.0 speeds.
i then rebooted, went back to default bios settings and changed volts in the followng ranges but had the same results as the first time:
vcore: 1.275 up to around 1.3125
rest left at auto
i am not sure that it is a voltage issue since it will not even post correctly but i'm willing to take the HT, NB and SB off auto and put them in the 1.28-1.4 range to see if that helps....
anybody have any guess as to why it will not even post correctly at 9x400???
(using OCZ ReaperX HPC ram)
rest left at auto
