Hi there. When my motherboard suddenly stopped working in my old computer (I tested everything else, including the cpu) I decided to purchase a new motherboard. I was due for an update anyways, the old CPU was only an Athlon 2100+. I decided to purchase a combo deal from Fry's which included an ECS P4M800Pro-M motherboard with a Pentium D 940 processor. I knew from online reviews that the motherboard was pretty much junk, but the deal was worth it just for the processor.
I put together my new computer using the same parts as my old computer with my new motherboard and processor. The only problem I had was a checksum error because I had two of the same sticks of ram in the motherboard, while in reviews and in the manual it says you have to have different kinds of ram in order for the computer to boot. After I traded one stick so I had two different kinds (totalling 1 gig) I was successfully able to install a new instance of Windows XP SP1 on my hard drive without reformatting (I tried using the old Windows installation but it would not boot, I'm assuming due to massive hardware changes).
After installing all drivers needed for my system, the computer has been running perfectly besides for one thing: I get random restarts, mostly when playing games.
My system includes the Motherboard/processor previously mentioned: ECS P4M800Pro-M/Pentium D 940, a Radeon 9600 Pro, an Enermax 330 W PSU, 512 mb Kingston memory (another stick of Corsair 512 mb that causes no changes when put in as well).
I have tried several things including using a different video card (Radeon 8500), purchasing and testing an Antec 500W Smartpower 2.0 PSU (http://www.newegg.com/Product/Product.asp?Item=N82E16817103937), several memory combinations and several different video card drivers. I have made sure that automatic restart on system failure is turned off, but I haven't seen a blue screen (the computer just straight restarts). My temperature levels are quite low and should not be an issue. All parts that I am using had once worked perfectly well before my previous motherboard failed, and all parts that I have used to test have also worked perfectly well.
I have done some searching and cannot find problems similar to mine with the ECS P4M800Pro-M. I had always been aware that the motherboard is not quality and prepared to purchase a new one, because the processor was cheaper in the combo even if it was by itself. However, I was hoping that the motherboard would work alright for me and that I wouldn't need to purchase a new one. I have tested everything I can think of, but I am stilll unsure whether the problem is definately the motherboard or not. If you think that the motherboard is DEFINATELY the issue, then I guess that will be what I replace.
Thanks for your advice, it is greatly appreciated.
